Primary Fuel Filter on 2001 Hunter 410
Darb
Nov 28, 2016
13
Hunter 410 Bayfield
Hello fellow Hunter owners. I have a 2001 410 that is factory equipped with a Northern Lights generator. It is installed in a sound box in the starboard locker off of the swim platform. I've only had the boat for a couple of seasons and have not yet changed the fuel filters. I see the secondary filter on the generator but cannot find the primary. There is a fuel shut off valve under the bottom of the port side lazarette that is accessible through a removable hatch but the fuel line is very difficult to view from that hatch to the generator itself. It is under the cockpit floor and runs behind the AC unit that is installed next to the generator. Can anyone offer some insight as to where the primary fuel filter is located or, if there is a primary filter even factory installed with those generators?
7,481
Alden 50 Sarasota, Florida
Not that this answers you question but are you sure it was installed at the factory? These are usually installed by the yard which commissioned the boat. If you know where/who that was, that may be a better source of info.
Also, I can't attest to every generator install but our's has only one filter at the engine. No "primary".
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
I did not want the dealer to install myGen and had the Hunter factory install my Gen
and no filter on the Gen but do have a Raco filter right next to my Yanmar filter.
Nick
Darb
Nov 28, 2016
13
Hunter 410 Bayfield
Hello Don. You are correct, I have assumed that it was factory installed but it may have been done at commissioning. I do know that it has been with the boat since it was launched. It was rebuilt years ago owing largely to it not being used and broken in correctly. I may be able to find out where she was commissioned, but I'm comforted by the fact that your boat does not have a primary either. I was hoping to hear that it was not unusual for that to be the case. Thanks.
Darb
Nov 28, 2016
13
Hunter 410 Bayfield
If I understand what you're saying Seadaddler, you only have what is essentially a 'primary' on your gen? There is not a separate fuel filter installed right on the generator engine downstream of the manual lift pump? I'm a neophyte diesel owner and am not aware of the various possibilities but I had assumed that the generator manufacturer would have included a secondary right on the motor. I am encouraged that you and Don do not have two filters, it may be a fairly common set-up.
Oct 27, 2016
0
Seattle
And now a word from the sponsor...
Replacement in-deck solar panel
Finally, a drop-in replacement for the in-deck solar panel on Hunters built from the early 90s through the mid-2000s. Improved for longer life and greater output.
See the product
Dec 25, 2000
5,942
Both the Yanmar (main) and Onan (Genset) on our boat have engine mounted fuel filters as well as each with a dedicated Racor ten micron filter between the fuel tank and engine.
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
Not sure how helpful this will be, but we have the 41DS and the Generator primary fuel filter / water separator on ours is mounted on the inside forward wall of the port side lazarette, just forward of where the generator is.
