		Dave Mauney
I am wanting to rig a preventer on an O'Day 35.  I can attach it to the boom at the main sheet bail and lead it forward on both sides.  The attachment point near the chainplates is my question.  I have read that the forward deck attachment needs to be just forward of the aft lower shroud chain plate and near the tow rail.  The tow rail on the O'Day 35 is teak an really only decorative.  The center chain plate for the upper shroud has a U bolt attachment for the lower cable attachement point.  Does anyone know of any reason why there would be a problem attaching a block for the preventer through this loop.  The U bolt is anchored throught the deck to a rod that secures to the lower grid of the boat.  The only thing I can see that would be a problem is that this could be a side load on the chain plate loop and may encourage leaking in the joint.  Wide open for ideas.Good WindsDaves/v DAMWEGAS
