My volvo MD11C is overheating and the raw water side seems OK. I am thinking about using Prestone Superflush to clean the freshwater side. Prestone's website says that their products are safe for all metals and dissolve even thick rust deposits. The volvo is mostly cast iron maybe steel in the cylinders. No aluminum. Anyway has anyone used these products??Results?? With the advent of aluminum blocks etc I haven't flushed a radiator in many years. Seems like I remember using Prestone products on an old ford that had a clogged heater with good results. I can't see any harm in trying this before trying to disassemble the engine to clean it manually.ThanksTom
