20 years ago I installed a pressure water system using Shields 148 VAC hose, 3/4". Over the weekend a pinhole leak developed under the galley sink. I went to the True Value and got a 3/4" x 3/4" PVC repair barb and then the fun started. Cut the hose and even with some water soluble lube, could not slip the barb onto the hose it was so stiff. So I go the wife's hair blower and tried to warm it up. Still too stiff. Finally I took my propane torch and warmed it up after wrapping several layers of alu foil around the last 2". That did the trick but you can see that the hose has expanded a fair bit, so now I am wondering if I used the right fitting in the first place and of course wondering how well the repair will hold up. Seems to me it should have been much easier....or does this hose just become brick-hard with age?
