Pressure washer suggestions, Peggy
72
- - Stockton Lake
Peggy, I assume what is meant by a pressure sprayer is a pump up garden type. I had at first thought people were saying to use a pressure washer but with the high psi I think you would damage things that you can't easily fix. Am I correct? I will try Simple Green and if that does not work then will ask for your KO ideas. Just got your book and will work on the sanation systed also. Jeff
Dec 2, 1997
8,913
- - LIttle Rock
Power washer not a pump up sprayer...
A pump-up sprayer doesn't even put out anywhere near as much pressure as a garden hose nozzle. A power washer is a "consumer" version of a pressure washer.. It's an electric or gas powered version that only has about 10-15% the pressure of a commercial pressure washer (the last one of those I rented was 15,000 psi machine...the consumer models are 1000-2000. I had a 1000 psi Karcher power washer for nearly 10 years (regular price in those days was over $300, I caught it on sale for $250)....actually bought it to clean up the "project" boat I'd just bought, and it did a bang-up job of cleaning the bilge as well as knocking 5 years of dirt off the hull and decks. And I continued to use it (along with half the people on my dock) for as long as I owned the boat...for bilge cleaning, spring cleaning, even to take the waterline scum off my bottom paint...WITHOUT ANY HARM to the gelcoat, anything in the bilge, or even the bottom paint. This past spring I "upgraded" to a new 1600 psi that Sams had for $127...and based on my experience pressure washing my deck and deck furniture at home, as well as my eaves, I don't think 1600 ps will harm anything if used to clean a bilge or any other part of the boat unless you put the nozzle tight up against it and leave it there. If you're afraid of 1600, there are 1200 models out there for about $100. IMO, power washers are the best thing for boat cleaning (and a whole bunch of jobs at home too) ever to come along.
Jul 12, 2004
285
Catalina 320 chestertown
Power Washers
I undrstand that a power washer will destroy the seal on double pane windows. They will then turn gray and be ugly. Just a thought. Paul
Dec 2, 1997
8,913
- - LIttle Rock
I've washed my thermopane windows with mine
for years. I wouldn't use a commercial pressure washer...but a "consumer" power washer hasn't hurt 'em a bit.
Sep 23, 2004
72
- - Stockton Lake
I will use powerwasher
Thanks Peggy, I have a 1300 psi unit that I have used on the exterior. I will use it. Jeff
