Pressure Wash the Deck?
PGIJon
Mar 3, 2012
856
Hunter 34 Punta Gorda
Any thoughts on using a pressure washer to clean the decks? Thanks.. Jon
7,513
Alden 50 Sarasota, Florida
There is lots of discussion in the archives here if you want to search. The consensus seems to be no problem with a low pressure pressure washer and to avoid sealant in joints as it can easily be blown away.
If it matters, I've used a 1600 psi washer for years on the non-skid effectively and is a great time-saver.
Jan 12, 2012
83
None None Bellingham, WA
Ditto what Don said. I've used a small electric PW several times w/o issue.
Jim L
Jun 13, 2012
49
Hunter 28.5 Kemah, Texas
Same here it works great. Even does a good job on the rubber tub rail along dock edge. Stay away from port hole screens too. A little tough on the Teak.
eianm
Jul 7, 2010
523
Hunter 42 Sydney
works great on the gelcoat- agreed on caution needed with genuine high pressure cleaners, but stay clear of teak- a pressure washer destroys teak very quickly- teak is vey soft and a pressure washer- almost any pressure washer will damage it right away- it blows away the wood fiber real fast. We have a guy on our marina with a 3 year old Jenneau with teak decks and he has totally trashed the teak with a small pressure washer.:eek:
