check this site
See the discussion on this site under Resources / reference library / B&R rig tuning tips.The pre-bend in a mast allows, by the use of more stays, a smaller, lighter section of mast. The stays, located at predetrmined engineered stress points, give the mast strength and rigidity. It also allows a deck-stepped mast, which has some advantages of economy, weight, and is easier to step. The pre-bent mast on a B&R rig with no backstay allows for a much larger roach in the mainsail. Pre-bent masts are almost always fractional rigs.
