Practical Use Of The Outhaul On Main
I was going to discuss the outhaul and the boom vang together but they are both very important sail trim controls so I decide to deal with them separately. Roger, whether you buy a loose footed mainsail or bolt rope probably doesn’t matter. The jury is still out on this. You’ll notice that all America Cup boat have the bolt rope and a very tall boom and the reason is they are trying to trap as much air as they can. It’s called end plate effect. I prefer the bolt rope but a lot of Catalina like the loose fotted model. A loose footer main is a bit easier to control from an outhaul standpoint due to the lack of friction due to no bolt rope. Actually, an outhaul will help with a slightly blown out sail. It certainly can’t hurt.The outhaul controls both draft position and draft depth. At this point I must mention that to be a proficient sail trimmer you have to completely understand the 4 elements of sail trim and they are draft depth, draft position, twist and angle of attack. Once you understand those 4 elements – and that’s all there is to sail trim folks- , you are miles ahead of 75% of the sailors worldwide. If you don’t believe just ask your dock neighbor or sailing friend to explain these items to you and see the answers you get. Anyway, for a detailed explanation of those 4 terms just access the archives section of the forum. Why the outhaul is so important is that it controls the bottom 2/3 of the mainsail. Sadly, most sailors don’t even use it. On most older Catalina 30’s it doesn’t even work due to a crappy design. If you are a C30 owner and would like to know how to convert to a simple external system just contact me off forum at yankee3223@juno.com and I’ll explain it to you as I don’t want to tie up the forum on a brand specific item. Increasing tension on the outhaul by pulling it aft moves the draft position forward and reduces (flattens) the draft depth (belly). Decreasing pressure by allowing the outhaul to go forward causes the draft position to go aft and the draft depth (belly) to get bigger. Actually, when you visualize what is happening in your mind or try it on the water you’ll see how obvious it is. When you want to increase and decrease the draft depth and move the draft position is a whole other story.A short version is that when you are sailing upwind in moderate wind, you want the outhaul about the middle position, which produces a moderately flat sail and reduces drag. As the wind builds, you want to increase outhaul pressure to produces a flatter sail. In choppy conditions, you want to ease the outhaul to produce a fuller, more powerful sail.
