powerwash question for Dave and others...
G
Gerard
I want to get a small powerwasher to clean my bottom a couple times a summer. Um...I mean the boat's bottom. I dock in slow moving creek that really lets the scum build up. What is the right psi washer for the job? Thanks...
Bob Reany
1300 PSI
My marina rents a small, commerical 1300 psi model that does the trick. I am not sure about the other metric, which measures the rate of water used. I am thinking about buying a 1650 model, that is not a commerical unit, but I would not go much higher. If the spray is pin point focused on the 1300 model, it can remove a little bottom paint
C
crazy dave
Gerard
Sorry I missed you but could not get the other fellow off the phone. Bob's response is hitting the mark. Too oftern high pressure will take the paint off and some. I suggest no more that 1000 but move it back and forth and not in one place. Hope that helps you. crazy dave
G
Gerard
Dave...
Thanks...had to bail 'cause phone was lighting up. Thanks for info. Sounds like I have a choice of nozzles and not to use the pin hole one. Thanks... Gerard
