Powering bilge pumps
May 28, 2019
3
Hunter 30 Kingston
the bilge pump is pumping but doesn’t have enough power to lift it the 3:5 feet to get the water overboard
Jul 7, 2004
8,534
Hunter 30T Cheney, KS
Is the pump intake clear? What kind of discharge hose do you have? Is it kinked somewhere?
I changed mine over to a smooth bore hose
Likes: Parsons
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
Usually pumps will state how much discharge head they can achieve....
Greg
May 24, 2004
7,213
CC 30 South Florida
Don't know what you mean by 3:5 lift but will take it that the plumbing was in the boat and working before you switched pumps. Make sure the discharge line is free of blockage, some bugs have been known to burrow in the discharge port. Shoot water in or out with a hose. Check the wiring installation for polarity and for voltage. Make sure the rating for capacity in Gallons Per Hour is the same or larger than the pump it replaced. If all checks out then you likely got a bad pump.
Apr 8, 2010
2,237
Perchance, is this a centrifugal pump like those inexpensive Rule pumps? Their thru-put is overrated IMHO.
They air-lock easily, too. "Cheapness" is their only virtue.
Replace it with a Jabsco chamber-type pump. I have a model 37202, and you should shop around for best price. These can be found for a bit over $200. Good quality, and lasting for a couple of decades is normal. These actually put out the flow that they promise.
Of course, as others point out, do check the voltage at the panel AND at the pump wiring connection.
