Phil
Up to a point, a sail develops more power when trimmed with a greater max camber. Power is work per time, and in this context it means more force is generated for acceleration following a tack or when busting through heavy chop. Speed on the other hand requires only a balance of forces and not necessarily the largest raw amount of force (and if you are thinking speed made good to windward optimum course issues come into play as well). This usually means a flatter sail. If you are one who thinks about such things, how do you go about continuously or periodically adjusting trim for conditions requiring power or speed? I'd be very curious to read your thoughts on the theory of why these adjustments work the way do (being such a wintry day, with Spring so far off and all).
