Power sailing
Jack W -H36
Just sitting here counting the days until spring, one question came to mind. Is there any limitation to angle of heel when power sailing or just running the engine to recharge the batteries? Thanks!
May 6, 2004
916
Hunter 37C Seattle
Yep
need to keep the raw water intake in the water and some engine manuals cite an angle limitation (probably do to crank oil intake pipe sucking air not lube oil, when oil goes to leward and leaves bottom of pan dry).
Dec 25, 2000
6,060
Hi Jack, my Yanmar manual says 15 degrees
maximum heel. Terry
Jack W
Mine too
Thanks Terry! That explains my alarm too Fred!! *pop Jack
