Have the tank and hoses empty
or as empty as possible, if you can still flush, get the lines clear or at least so that the standing water is clean.You will get some back flow from anything standing in the lines.Over all, not too big a job, I think you will be surprised at how easy it is to rebuild the pump.Watch out for the plunger rod, if it has a clip to hold the plunger piece on, then Jabsco offers to replace it with a new piece, I can't recall if this was info in the rebuild kit, or if this info was provided on this site. I found out about it after I had rebuilt the unit and the plunger broke.Good luck.Bruce Neon Moon
