I'd pull the board and check that it isn't "swollen" in the middle, maybe by water intrusion or delamination. Or it could be an obstruction in the trunk, as mentioned above. It probably wouldn't hurt to replace the pin while you are at it.
As for getting it out of the trunk to drop it, we use a honking big screw driver to pry ours out.
