Bob England
On Sept. 17th I crossed Lake Ontario from the north shore to the south and return in near-gale conditions. Sustained winds were in the mid 30 knot range and there were short steep waves that looked like about 3 meters at times. With my single non-sailor crew, the boat handled the conditions extremely well. Returning well after dark, we quickly put the boat to bed, and I went home feeling a little proud of my boat and myself. We were almost the only boat visible on the lake that day. Due to work and family pressures I was unable to return to the boat until yesterday. What I found was sobering if not scary.On the '89 H30G, and I believe on the 90-94 30T which has the same hull, the thru-hull transducers for boat speed and depth are mounted in front of the keel, which is just behind the V-berth inside. The hull liner has an access opening over this area, which is covered by a solid 1/2" teak plate. This board also serves as a step up to the V-berth. The clearance between the inside of the hull and the bottom of this plate is on the order of 3-1/2 to 4". (I haven't measured this, so this is just an estimate.) My boat has a B&G multifunction instrument, and the depth transducer is almost as tall as the clearance. What I found on inspection yesterday is that the 1/2" solid teak board covering the transducers was pushed up and split right in half. It gave the appearance of having been hit by a hammer blow, and the screws were ripped right out of the fiberglass. This could only have been caused by flexing between the hull and the liner. The plastic transducer mounted in its plastic thru-hull had come into forceful contact with the board and split it right into two pieces! While the boat did take quite a pounding, this should not have happened. The scary part is, if the plastic thru hull had broken instead of the teak board, there could have been a 1-3/4" hole open to the lake. This water flow would have overwhelmed my (typical) anemic electric bilge pump and my Whale Gusher manual pump, and, hours from shore, the boat could have sunk! (Yes, I do carry a set of wooden plugs to ram into holes, but it still would have been pretty unpleasant facing that challenge under those conditions. If the thru-hull had merely cracked, the boat could have sunk later at the dock in the 3 weeks I was away.) I don't know how serious this sounds to other owners, but I suggest you check the clearance between the tops of your transducers and the cover board before your next heavy-weather outing. Two solutions come to mind. 1. Attach the cover with a piano type hinge and allow it to move up under force from below, and, 2. raise the cover board higher with a substantial shim plate and/or cut away some of its bottom to increase the clearance. If anyone out there has an idea about how much movement there can be between the hull and liner in this area, I would be interested in your comments.Thanks,Bob England
