Potable water filtration system
500
Hunter 36 Chicago
Want to add a water filter for the whole potable water system. Couldn't find anything in the archives. Does anyone have suggestions as to a good filtering system? Looked at 3M web site but wondered if anyone had experience with any particular brand. Thanks for any suggestions.
Ross
Jun 15, 2004
14,693
I use a domestic whole house filter with a carbon cartridge
Figuring out where to put it was the big problem.
RichH
Feb 14, 2005
4,773
Go to home depot or Lowes
buy a 2.5" dia. X 10" standard industrial plastic housing (3M) and dual "carbon packed 1,2uM (ABSOLUTE RATED to 99.9% efficiency) particulate filter .... attach the filter housing to the dock charging hose, and fill the tank .... regulate the flow to be 'as slow as possible' through the filter to allow the maximum 'residence time' with the carbon in the filter; dump the water out of the filter to prevent growth when done. Installed water particulate filters or carbon filters on boats (if not used almost daily) will become a stagnant source of bacteria, etc. growth. Clean and then Sanitize the tank/piping, consider to thoroughly CLEAN or replace the vent line and consider to protect the inlet to the vent with a bio-blocking hydrophobic vent filter ..... or simply a fist sized wad of absorbent cotton covered with bandage gauze and taped to the end of the vent .... keep dry and change yearly).... add Clorox to keep the 'growth' to a minimum ... add 'just enough' Clorox to the water until you can 'just barely' smell the Clorox in the spiggot water. and you wont need anything else (for travelling in the USA or Canada). ;-)
RichH
Feb 14, 2005
4,773
Best place to locate .....
Put it onto the end of the hose that you use to fill the tank. Empty the housing when done.
May 6, 2004
916
Hunter 37C Seattle
I just put a small filter on the cold water supply
to the galley facet, figuring I don't need to filter shower water or head sink water used to wash hands. But Rich is right, the filter housing always has water in it and if left unused for a few weeks, the filter gets a green slime on it.
Dec 27, 2005
500
Hunter 36 Chicago
Thanks for all the replies
You all probably saved me quite a bit of money since anything that says 'Marine' on it is twice the cost. I'll check out HD on the way home. The biggest reason I wanted a filter is because the water from the marinas around here (at least in my experience) has a lot of sediment. I was also a little concerned about the condition of the water since filling up at the end of the docks means I may get some water that has been sitting around stagnant for some time (I'm on a can)even though I let it flow for a few minutes before filling up. Don't know if this is a cause for concern...never thought about the filter getting slimed up - good point.
Dec 27, 2005
500
Hunter 36 Chicago
Jim, is that a marine unit or a standard household filter?
I'll check out their website. Thanks!
Rick9619
Off the shelf will work
All the advice below is good. I use the two filter pack system available from HD also. A marine app is probably an unecessary expense. I have mine just downstream of my water pump. Easy to addapt your lines from the local marine exchange. GOOD news is, they tell you when they need to be changed. You will notice a drop in water pressure that isnt assoicated with something mechanical. Oh and I dont use clorox as a preventative measure. I have aluminum tanks. Cheers and good drinking!
May 24, 2004
7,213
CC 30 South Florida
Just purchase bottled water.
Unless you are a liveaboard or full time cruiser it may not cost effective to install a water filtering system. On a one week trip we usually stock a case of 24 bottles for drinking and 2 gallon bottles for coffe and cooking. The water on the tank is used for washing dishes and showering. Our cost of water per week of sailing is close to $1 a day. Other than carrying the bottles in and out there is no maintenance or filter replacement costs.
Ross
Jun 15, 2004
14,693
If you drink the tap water at home then use that to fill
jugs and bottles and freeze it and keep it in your ice box. You can kill two birds with one stone that way.
Dec 27, 2005
500
Hunter 36 Chicago
I agree that's the best way to go
I've been using those foldable 5 gallon plastic camper jugs to carry filtered water from home out to the boat. Problem is I'm on a can and it gets to be a pain sometimes carrying all the water,food,etc. to the dingy and then out to the boat for an extended stay...lot of good advice in this thread though and some precautions.
Feb 6, 1998
11,759
We use..
For drinking water on board we use a GE whole house, cartridge style, water filter set up using this cartridge http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100076639 & this GE housing http://www.geappliances.com/smartwater/model_fs.htm?GXWH04F . It installs between the output of the pump and the fixtures and is very, very easy to do. A Brita http://www.filtersfast.com/Brita-On-Tap-water-filters.asp faucet mounted filter is also in the galley on the faucet for double filtration! We drink right out of our 1979 tanks with this set up no problem! I do do an annual shock treatment at he beginning of each year though. As stated below the trick to filters on a boat is to keep water flowing. I'm on my boat at least five days per week and run water through every time I'm on board. I change the Brita about two to three times per season and the GE whole house about twice.. The combination of the Brita and the whole house filter works great! Oh and one huge benefit of the Brita is that with the filter in the on position you use very little water because it acts like a flow restricter! At home we also filter our water but we have a dedicated single cold water "drinking water" faucet and the dual filters mounts under the sink! It cost us about $100.00 at Home Depot, with the faucet, and has paid for itself ten times over with what we've saved on bottled water costs. We get about six to seven months out of the filters..
Ross
Jun 15, 2004
14,693
Every six months we get a statement of water quality
from the water company that supplies us. This statement is the results of testing done by the state for water quality. I have seen no need to buy water in the stores or to add more filtration. However if I was on a well my water system would have filters and other treatment devises in the system.
Feb 6, 1998
11,759
Ross..
We get the same report however when we had our actual tap water measured there was a BIG difference. These utilities tell you basically what you want to hear but the external factors that happen between the supply and your tap are a long, long set of pipes. Corroded, rusty or leaking?? The taste difference alone was worth the $100.00 to us...
Ross
Jun 15, 2004
14,693
Our water company opens the fire hydrants about twice each year to flush the lin
. My basic measure of water quality is my nose and mouth, if the water smells good and tastes good and makes good tasting coffee and tea then I am satisfied. Because I know it has been treated for pathogens and filtered.
Dec 3, 2003
2,101
I have seen users...
... use SEAGULL brand drink-water filter systems. I have also seen kive-aboard use a filter system right on the dock faucets. But don't ask me the names. Take a walk on your dock and check it out.
7,689
Alden 50 Sarasota, Florida
Water filter myths
Other than what is Federally mandated, I'm not sure how extensive the testing and reporting by municipal water treatment authorities really is. In our case, the reporting typically falls short of reporting analyses for most common viruses, pathogens, many heavy metals and even some bacteria, many of which have caused locally severe health implications over the years and none of which can be effectively removed by any of the filters mentioned previously. Some longer residence time carbon elements are great at removing some bacteria, color, odor and some objectionable taste but that's about it. They are all pretty much equally effective at two things: 1. removing objectional taste, and 2. give the consumer a false sense of security about what they are drinking. The concern regarding reliance on the ubiquitous bottled water substitute is that they, for the most part, are essentially expensive and unregulated municipal water marketed as something else. Federal water quality standards applicable to municipal systems are not applicable to bottled water making them far less regulated in terms of minimum quality. As RichH and others may have said, stagnant water is about the only thing we can avoid. The only safe liquids are Johnnie Walker Blue Label or Crowne Royal.
Ross
Jun 15, 2004
14,693
This is a link to the water quality report that we receive
regularly.http://www.harfordcountymd.gov/dpw/ws/waterquality.html
