Post Recommissioning Engine Alignment
Dan_Y
Oct 13, 2008
522
Hunter 36 Hampton
As part of overhaul we replaced the prop shaft, coupler, and cutlass bearing and also reworked the prop on our H30 with 2GM20F. So after I’m in the water, how do you tell if the alignment has changed? Increased vibration? The archives talk a lot about initial alignment but just say you have to recheck after being in the water a few weeks. So I think that means to start over.
The mechanic said that I would have to loosen the coupling bolts and recheck for a consistent gap between the flange and coupler and recheck centering. He also said that the torqueing the coupler bolts on small engines will pull a slightly misaligned coupler and flange together with no gap, hiding the misalignment and putting load on the tranny and cutless/strut. And it’s way too cold yet to get under the boat to see if the shaft is not centered in the cutless, but I’m not sure I could see that on a 1-in shaft anyway.:confused:
Thanks,
Dan
ALNims
Jul 31, 2014
208
Hunter 356 Huis Ten Bosch Marina, Sasebo, Japan
Thanks,
Dan
I suggest that you contact Yanmar technical support for guidance and ask them their take on your mechanics advice. I also think your mechanic is pretty much correct. But, it never hurts to check with the experts that designed and manufactured the equipment in the first place.
