Possible Accident Waiting to Happen
1,015
O'day 30 313 Georgetown MD
On my Hunter 25.5, the Pop Top is held up by one simple slide and twist latch. Every time I put it up and put the latch in place I cringe at the thought of how that would hurt if it let loose and came down on my fingers, hand, wrist or any other body part. I look at it as a guillotine. The latch is just not secure enough for my liking. What have you 25.5 owners done to secure the hatch when up. I have used the vang around the mast, but I was thinking of doing something more easy to lock in place and provide that security. Any thoughts?
Roy G
Jun 18, 2010
17
Hunter 25.5 Smithville Lake, MO
I have the same boat and share some of your concerns with this set up. I know that the owners manual says that the pop top is for anchored or docked use only. It's not supposed to be up when sailing.
You could easily run a rope around the mast through the back two legs of the pop top and that would stabilize it better than the slide stop and bent hook arrangement.
Good Luck
Roy
Aug 11, 2011
1,015
I think I might bolt on two eyes, use an adjustable strap with safety hooks on each end, a stop on the front of the mast as to avoid it dropping. I will try later to attach a drawing.
Nov 16, 2010
81
Catalina 22 Mactaquac Headpond
I'm not sure if it would be adaptable to your poptop but Catalina Direst has a kit for the C22 that uses gas struts to take the load off. Might work for you.
Aug 11, 2011
1,015
Sorry about my inability to draw, but I thought this would give a good presentation of what I thought I might do. Any thoughts?
Aug 11, 2011
1,015
All it took was a whole day working on odds and ends on the boat to come up with the answer. On each side of the sliding hatch is a grab handle, about 1 3/4" x 1/2" and long (no sure how long exactly). On one side I have the main sail line hooked on to an eye bolt, while the sail in flaked on the boom. So if I were to duplicate the eye bolt on the other side and have a line with a carabiner on each end, then the main sail line could hoist up the pop top and be lock in place by both the sliding latch on the mast and as a secondary safety measure the rope clutch. Absolute genius, even if I say so myself!!!!!
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
My O'Day 23 Pop-Top had pins that were inserted into the four support struts to hold the top in the raised position. Is that possible on your boat?
Aug 11, 2011
1,015
Not sure, but i don't think so. The four tubes that support the top when up are fixed with brackets and pins at each end, (top and bottom). I will review your thoughts this weekend when I get down to the boat again.
