G
Geoff Kloster
These are some thoughts/questions to follow up my post on my plans for replacing my sanitation system in a Pearson 323. There is a 30 gal water tank in the bow. Our present sailing style does not require much on board water and we have not used that tank. Should I replace the 30 gal water tank with a holding tank rather than the 14 gal tank I plan for the starboard v-birth storage bin? It will be easier to run a good vent line to the bow this way. It will mean much fewer trips to the pump out facility. It will require more than the 6 ft from head to tank as suggested in Peggie’s article; if the vertical run to/from the anti-siphon valve is counted it will be at least 8 ft. What will it do to sailing performance? The P 323 is a heavy boat, 12k displacement and 32 feet long. In a few years we hope to do some longer cruising but with in the Great Lakes. How necessary is a large water supply? Peggy talks about the necessity of getting air into the holding tank. Has anyone tried a bubbler like those used in fish tanks? Could it be run for a minute every time the head was used and give adequate air for aerobic bacterial action in the holding tank? If I stay with the 14 gal holding tank I’m thinking of using the 30 gal water tank for the head fresh water supply. The thru-hull for the head supply requires removing cushions and a storage bin to get at it. The storage bin is a tight fit and the valve far enough under the settee to require a bit of manipulation to get to. Thus a hook up to the tank would eliminate one hassle on leaving and returning. (We’re in Lake Michigan, so I can’t argue for the fresh water?) If I put only 10 gal in and fill each or every other time the tank is pumped I won’t have a large weight in the bow. If I discover she sails better with weight in the bow I can leave that tank filled and top up each time I pump the tank. Perhaps the KO stuff could be put in the water tank and benefit by all hoses having the enzymes in rather than just the holding tank? Any thoughts?I think I’ve run out of questions. Thanks for any help.Geoff
