Hello,
I have a VP MD6B and a kombi reversing from -75 in my Vega. During
last winter I changed the bearings and sealings of the kombi, stern
gland and renewed the sternbearing. Even dismantled the propeller
boss (monitoring tube and shaft)and changed the o-ring there. So,
everything were dismantled, checked and cleaned.
Now I have started to reassemle the parts but faced problems because
the adjustment of the prop blades does not function correctly. I
can't get the blades to the sailing position and I am afraid that
installed the blades some how wrong (poor documentation before
disassembly).
I started the installation by checking that the marks on the blade
and boss match but the adjustment still doesn't work properly.
I am quite sure that the sleeve in the kombi is OK but if the
position of the blades is not OK, the result is that even the
touch of the sleeve and the toothed shaft is not correct =
adjustment range not right?
The question is if somebody has pictures of the propeller in full
feathered, free and full forward positions or can otherwise tell how
to check the positioning of the blades and the sleeve.
All advices are welcome.
Best Regards
Timo
disassembly).
Best Regards
Timo
