Ports
Dennis
A friend @ the marina has a 1982 Hunter 26 & no computer so he asked me to post this- He says there are two sizes of opening ports on his boat- he needs to replace the larger of the two including the thru hull- can anyone give info. on how he can find these ports? Hope this is enough info. Its all he gave me.
Dec 2, 1999
15,184
Something is NOT correct!
Dennis: There is something wrong here. Is the boat a 26? Is it a 1982?
C
CaptJeff
Try the ThriftyMariner
Check out The Thrifty Mariner, they are now located in Largo,Florida(West Coast,St Pete area) They carry Surplus Bomar ports,Hatches and NEW Items. They also carry alot of the older Bomar/Gray Portlights and Hatches, They have the Trapezoidal Hatch in Stock for $295,Aluminum frame, smoked lens. Call them at 813-390-7474 or www.thriftymariner.com
Dec 2, 1999
15,184
Capt Jeff:
Capt. Jeff: They did not make a 26 in 82. Maybe a 25 or 27 in 82. Or a 26 in 92.
Jim Maroldo
Ports?
As soon as you find out what this boat really is, you can also try Hunter Marine themselves. If they don't have what you need anymore, they can tell you who does have it! Jim maroldo s/v: Lil' Wass Ett
Dave Weir
Port Size
With regard to replacing ports, a Hunter of that vintage probably had Bomar/Gray ports. The first thing to do is identifiy which one--take all the measurements including the lens, inside openning and exterior frame. Then go to www.pompanette.com and follow the links to Bomar/Gray and portlights. You will find a table listing all the ports--I think Bomar has maintained them all in production. You can buy them there, or try www.sailnet.com--Sailnet carries alot of them, probably at better prices. Hope this helps, Dave Weir Hunter 25.5 "Last Resort"
