Ports Crazing
150
Hunter 23.5 Cypremort Point, LA
My front port across the front of my 1994 23.5 is starting to show crazing from exposure to the sun. Will having a Sunbrella cover made to go over it prevent further crazing? Thanks, Jonathan Costello
C
crazy dave
Lexan?
If it is surface, then you can sand with 400, then 600 and then 1000 with wet and dry sandpaper. Then compound it but make sure at low speed with a buffer moving it constantly. Never use acetone or you will see carazing
Mark
Tell me more Crazy
I have many scratches on the variouse windows and hatch slide on my 260. Using the method you mentioned will the lexcen come up like new?
