portlite removal
36
- - vermont
Can some one give me the steps to remove the port lights so i can recaulk them. Does the out side trim just pull out. Does this mean that the only holding the out side trim is the caulking ?
May 31, 2004
11
Hunter 27_75-84 Lake Ray Hubard, TX
Gray Portlights
Assuming that you have the Gray (brand, not color) portlites, You are correct, you need to CAREFULLY remove the trim rings on the outside. They can get brittle with age. I used a wide, thin puddy knife. Others have used a thin wire.... Once you have the trim rings off, then unscrew from the inside. Make sure that you seal the cutouts to prevent future (or additional) water damage to the plywood core of the cabin top. Check the photo archives, there are some good pictures that have been posted. Chuck Petty S/V Following Sea 1984 H27
