portlights
2
Oday 37 -
hi all i'm replacing the portlights in the salon and could use some help on where to find the best replacements thanks rich
Mike
Do you want the original style/type?
If so then Rudy will probably be your best bet for the original port light. If that isn't important then there are more web sites out there (including this one) for what you want than you can shake a spinnaker pole at. Pretty much you can measure them and order them per the dimensions you send to the supplier. If you want to talk to someone; a good chandlery will provide you with info on what's out there to meet your budget and needs. Good Luck, Mike
