Cost, Effort, and Aesthetics
Our H-35 has Beckson ports which we replace a couple years ago with the same type and style of port. The advantage is the cutout is exactly what is needed for the replacement ports, which make the installation easier because the cutout doesn’t have to be altered size-wise. Surprisingly, many people prefer the original look vice something different even though the revised ports may cost a lot more. Cost: These are probably the most cost-effective ports available.Effort: still enough to want to avoid doing the work; however, it would have been much more if a different port was used. Time to change all four ports was about a day as this was my first time. If one would have to redesign the installation it would take a lot longer.Aesthetics: not all that bad. Sure, I would like to have had stainless but, frankly, the boat doesn’t justify it. One would never get the money back out in resale. The old ports lasted for around 12 or 13 years but probably should have been replaced a few years earlier as the Plexiglas was quite crazed, the gaskets were shot, some of the screens needed replacing, and a few knobs had cracked. The new ports made a tremendous difference in the appearance and from the inside the boat looks almost like new – and look ma – no leaks!!!. Yesterday I replaced the aft oval Grey ports to complete the project. For info, oval port used in late 80 vintage boats: Grey # G616-28SS, Pompanette Port # 616 WHT/TINT SS T-Ring. Grey is a subsidiary of Pompanette. Link below.Next project: Replace the 2-inch wide navy shear stripe but need to find a source.P.S. Deciding what to do is a major part of the battle - good luck making it!
