More details
Ron - I forgot to mention to use 40lb test fishing line, not piano wire, to "saw" through the old sealant to get the window off. It won't scratch like piano wire. Don't get impatient and try pulling off the window. I bet it would break (perhaps indicating that it's not Lexan).The factory said the job is best done when the weather is cool and dry.The factory suggested to scuff up the hull and window where the adhesive goes with 80-grit sandpaper for better adhesion. The dealer who sold me the 795 didn't think that was necessary, especially with the primer. I was afraid of the scratches from the sandpaper showing so I didn't do this step, although in retrospect I had no business going against what the factory would have me do.I was running out of time this morning and didn't give this detail: I clamped the bare window in place by running lines from the trailer frame over the deck to the trailer frame on the other side. I put masking tape on the hull all around the window, about 1/16 to 1/8 inch away from the window edge. Then I went inside and put masking tape on the inside of the window around the holes and on the hull inside the windows, again about 1/16" from the window edge. Another way would have been to mark the hull holes outlines on the window with a pen or something and then put on the masking tape after removing the window again. After removing the window I put masking tape on the outside of the window (up to the edges). It's hard to explain all this but the end result is that when you press the window on and the 795 oozes out, it only gets on masking tape, inside and out. I cleared away the excess with a rounded rubber grout smoothing tool and peeled off the masking tape within 5-10 minutes afterwards while the 795 was still wet. The next day I scraped away any little irregularities with my fingernails. The result was a fairly clean job! Lastly, he said to clean up excess ooze with Ivory soapy water, but with the masking tape I had nothing to clean up.Good luck! The whole thing was so traumatic for me, and hung over my head for so long, that I wanted to pass on as much as I could to help others....RickM...
