Hi Maine Sail,
I'm working on following your guide for replacing portlights. I have a '75 Ericson 35-2 and I'm replacing the smaller portlights with the New Found Metals 14x4s. When removing the factory pieces I found that the cabin top wasn't a sold piece of fiberglass as seen in your pictures and the videos from New Found Metals. Instead its an outside layer and an inside layer, with a varying air gap, and on some holes a strip of epoxy between the lower layers.
My question is, how should I go about filling this in? I've read on the Beckson site that they recommend foam or plywood for their installs, but wanted to get your opinion.
Thanks!
Thanks!
