Portlight Plywood Core Replacement
155
Lancer 25 SoCal
Good evening all. JFKSail reported problems with rotten plywood core surrounding his portlights. I too had discovered damage on my L25 after removing them, especially the center ones.
What I did was take and angle drill and remove the plywood core about 1 3/4" all the way around the portlight. This takes about an hour per window.
I then used the waterproof epoxy paste (1 hour curing time) from Home Depot to fill in the void. The technique I found that works best is to cut the paste a little with acetone and work the paste in using a pair of tongue depressors sandwiched together and dipped in acetone. It takes about 16 oz of epoxy to fill the void per window.
BTW... I used this technique on the Beckson PF714 (7"x14"x2"). My core is still solid surrounding the PF310 (3"x10"x1.25") and if required I haven't figured out how to get the drill bit into that small space. Suggestions welcome.
caguy
Sep 22, 2006
4,004
There is a water soluble epoxy that has the consistency of water but dries hard. They use is on old rotted wood in home restorations. I used it on the floor boards of my 29 Model A Ford and it worked great. The wood really soaks that stuff up then dries stiff as a board (pun intended).
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
The usual approach
People usually tighten an allen key in their drill. A 90 degree drill might help too.
Nov 26, 2007
155
Lancer 25 SoCal
Frank, what's the product name? Also, how is your Lancer restoration going?
Bob, I used a 90 degree angle drill and that chuck length combined with the drill bit would be to long to fit into the smaller 3" space. Steve
caguy
Sep 22, 2006
4,004
Nov 26, 2007
155
Lancer 25 SoCal
Bob, do you think an allen key will remove wood or do you make it really exciting and grind the end to a point(;-)
BobM
Jun 10, 2004
3,269
The multimaster tools (I too have the Dremel version which is about $100) work great for boat work, but might be tough to fit in a 3 inch space. The allen key will work great for removing mushy balsa core and will fit into a 3 inch space. It may work for plywood too, but your mileage may vary. You can make a filler any consistency you want with resin and microballoons.
Nov 26, 2007
155
Lancer 25 SoCal
I'm fortunate Bob that the core surrounding the smaller, 3" ports is solid. I may soak a mixture of resin thinned with acetone and then check it in a couple of years. Steve
BobM
Jun 10, 2004
3,269
That's good. Did you find replacements the correct size or are you just reinstalling the old one? I always wondered if there was a replacement for that fixed port readily available.
Nov 26, 2007
155
Lancer 25 SoCal
Here's what I pulled from the website Bob, which I believe will fit. Steve
Beckson Marine, Inc.
165 Holland Ave Bridgeport, CT 06605
Tel: 203-333-1412 Fax: 203-384-6954
PF310-WS-10 WINDOW,3x10x1.25",wht/smk EA $71.00
PF714-WS-20 WINDOW,7x14x2",wht/smk EA $126.75
BobM
Jun 10, 2004
3,269
Great. It is always good to have this stuff in a thread so that when someone searches for Lancer 25 port replacement it comes up. Thanks for sharing.
