Rotten to the core...
Thanks Ed for calling me an expert... I'm not so sure that is a distinction that can apply to anything regarding boats or people who work on them. Especially rotten ones! Peter, here is what I have learned and others I'm sure will follow with very good advice as well. First of all, do not despair. This is a totally repairable problem that as Jim had stated could have been completely avoided by the factory had they sealed the core in the first place. But to Hunters defense, I have a friend who has a Morris 32, a very expensive boat by anyones standards that had the same problem and actually had regular plywood in the core instead of the marine ply that Hunter used. It was a lot worse for a much newer boat so spending more doesn't always buy more. OK, back to the core issue. The good news is, the wood on the cabin sides does not extend onto the cabin top or the side decks. The wood is there as a filler and compression modulus for the outer skin and inner liner so that the portlights can go in without squeezing these two together. That said, you still need to fill this in but the fact that it has rotted out doesn't mean your boat is structuraly compromised at the cabin sides. If you'll notice the radius at the cabin top and at the deck it would not be possible for the wood core to be sandwiched in those areas so the Fiberglass is the main structural member on the cabin sides. When you remove the rotten wood, I just used expanding foam to fill in the large gaps and then used thickened epoxy to seal the edges of the portlight openings that will now be water tight. Silicone can then be used as a sealer as that is really all that will stick following they original installation by Hunter. This is because silicone leaves a film that nothing else will adhere to but more silicone unless it is completely removed. Hunter used white silicone on my boat so yours is probably the same. If you have any more leaks in the future you'll just see water leaks into the cabin as Jim suggested but your wood will be sealed with epoxy so no wood damage will occur. You can then just re-seal them and forget about them for a long time to come. After all they lasted 20 or more years to this point. Gene, Ed and I and some others went with the New Found Metals portlights. They are nice but present some idiosyncrasies of thier own with respect to installation and drainage. I'm still not finished with mine and if I had it to do over again I'm not sure I would go this route but they will be nice when they're done. I think Ed shares the same sentiments. Good luck, there is lot's of data on this forum so you're not alone and when you're done you'll be an expert as well.Tom HadouliasS/V Lite ChopH37C
