Porthole Weather-stripping on 1980 H30
Stephen Ord
I have a 1980 Hunter 30 and the opening porthole (7.5"x15" approx)needs s new seal on the inside where the opening part meets the frame. It looks like it is a round gasket material pressed into a groove in the plastic. Does anyone know where to get this material and what model # the porthole is?
Dec 2, 1999
15,184
couple of choices.
Stephen: I believe that you can get the stuff from Bomar/Gary www.pompanette.com The Thrifty Mariner also has it. I think that the stuff that Beckson uses will also work.
J. Tesoriero
Bomar/Gray # 715AD
The PortLights areBomar/Gray #715AD, 15 9/16W X 7 1/2H. The internal gaskets are 3/8" foam. Gasket is available directly from Bomar ($2/ft) 1-603-826-5793. Some Bomar parts may also be available from the Rigging Co, R.I. 401-683 1525
