portable potties?
Richard
Peggie, I don't have much room for a holding tank, what do you know about the Sealand (or similiar)portable potties (5 gallons with pump out) or the Sealand permanent heads (9 gallons with pumpout). Either of these would solve my space problem as the head basically sits on the holding tank. Thanks, Richard
Peggie Hall/Head Mistress
If you have enough room in your head
for the tank footprint (about 20" x 20"), go with the 911-M28 "Marine Traveler." It has the same bowl as a VacuFlush, is full household height, and uses pressurized flush water (only a pint or two/flush), so no reservoir to to keep full And it holds twice as much as the 5.6 gal Sanipottie 965-MSD.
