G
Glen Stevens
I recently purchased a 2000 watt Honda generator to supplement my power supply while on a mooring. Presently I also have a 2500 watt Heart/Interface inverter that also charges my batteries when hooked to shore power. However, when I plug my new generator into my shore power hook-up, the generator trips out on overload numerous times at the outset as the inverter seems to be pulling more amps than the generator puts out. This happens only when the generator is initially plugged into the shore power plug, and it seems the inverter goes through a power cycle where the initial demand is very high, and then levels off at a sustainable level. After re-setting the generator numerous times, the two settle in and run fine together. Although I know that getting a bigger generator (or smaller inverter) will solve my problem, I was wondering if there are other options available to throttle back the demand from the inverter to prevent it from tripping my generator. Any help would be appreciated.
