Yesterday I was out sailing with and heard a pop. Had no idea what it could have been until I returned to the slip I saw a crack in the port side window. Clear through from bottom to top. Three questions. 1, Has anyone had this happen to them? 2, Any idea why this would happen after 26 years ? 3, can I find a replacement through Catalina direct or should I just go to a local plastic dealer with the old window as a template? That was sort of 4 questions.
As a short term fix I was thinking of running a bead of crazy glue or some similar thin glue into the crack and let is wet up. Maybe that may even be a simple solution for the season.
Thanks in advance for the input.
Cheers,
Curt
Cheers,
Curt
