port job completed
165
Hunter 37-cutter San Francisco Bay
I posted a photo forum project report on the port job, tried to be specific to 37 but obviously applies to a lot more. Thanks to several of you who provided vital informastion, tips and even one really good new port. I'm glad I did it, but would not want to tackle that again for another 25 years! check it out. Sanders
Jun 2, 2004
87
Hunter 33_77-83 Montevallo Al
cutting off port projection
Glad your port job worked out ok. Your photo forum article mentions cutting off the ports. i had the same problem and used the following procedure which worked well for me. 1. Use a combination square and pencil to mark the desired cut off line. Just extend the blade the requisite distance past the square, tighten it down and then keeping a sharp pencil at the end of the rule, run the square around the port barrel, marking the cut line. 2. make a starting slot on the cut line with a dremmel tool cut off wheel. 3. use the inexpensive Stanley combination hacksaw keyhole saw to saw around the line. 4. Use a rasp and then 80 grit sanding paper with a block to cut out the saw marks. then round the sharp edges with sandpaper. Probably takes no more than 15 20 minutes per port.
Jun 2, 2004
5,802
Lookin' good!
Nice work Sanders. You know how much I wish I had done that. Instead of those non-draining, tough to install bronze NFMs I mean. Keeping the spigots short is key on the plastic ports. Otherwise they will get stepped on and cracked. Boat really looks nice in the pic. I hope you are getting lots of time on the water.
