Pop-top Support Pole
2
Macgregor 25 Lake Jordan, N.C.
I lost one overboard last weekend and want to know if/where I can buy a replacement? Thank you, Mike
J. Barrett
Make one
Mike, you can make a replacement. I have one original and one home made. All you need is a bench vise to crush and bend the ends. Works just as well as the original. And yeah, they don't float well.
Aug 24, 2006
62
- - Berkeley Springs,WV
Then use a lanyard
I too have one factory and one homemade. I simply squished aluminum pipe flat and bent to the right angle. Then I tied a line around each of them and keep them attached to the boat.
Aug 23, 2006
2
Thank you!
Yes it sank immediately so will have my replacement tied on! Off to Home Depot/Lowes this evening to try and get some tubing... Mike
