Before I say it I concede that there may be sail shape issues and that it may not be perfect...but I was thinking of running a line to a mast base block from the clew of my 100% genoa and then back to the cockpit for a poor man's version of a self tacking jib. Sort of a permanently installed downhaul like when using a whisker pole...only using it as a sheet (without the pole of course). It would make tacking a snap, especially when single-handed.
I figured I could still keep the port and starboard jib sheets...just keep them loose so I could retain the option of tuning the genoa properly if I am not lazy at any particular moment.
I already have the mast plate and free base block. Probably screw-up the shape of anything bigger than the 100% genoa sail, but I also have a 75% (or so) genoa I could try too.
Thoughts?
Thoughts?
