Find a dedicated poop spot
Congratulations on your new puppy. Obviously don't train him on the boat till he's trained in the house but once that happens, you should start on the boat. First, find a dedicated place for him to "go". Make sure it's out of the way but easily accessible for him. Do you do a lot of daysailing or are you cruising? If you see rough weather, you might have to find an indoor location too but I don't recommend it!!!
Anyway, you really should install some indoor/outdoor carpet in the spot cuz they really like to do it in grass & it also won't negate what you're trying to do at home. Pooping on the floor is a no-no, right? So make it as "outside" as possible. It might (and this is gross) be helpful to take a sample of his, place it on the mat, let him smell it & identify it as "the" place to do his business, then hose it off.Now, this is all stuff I've heard second hand from other cruisers w/dogs, so take it with a grain of salt. You have to do what works for you but this is a place to start.Good luck & have fun with your puppy!LaDonna
