NewGlass on decks...
I used it for 2 seasons on the non skid and cockpit but didn't like it there. It works wonders on the hull though. This stuff is very similar to the floor wax you use at home in the kitchen, however obviously it has UV inhibitors and other stuff for marine use. The problem on the decks is that dirt will get imbedded in it and it will be hard to clean. It did keep the decks clean, like I said nothing sticks to it, you could see dirt roll right off with just a hosing. The application is very simple if you have a white hull, clean it good, don’t worry about oxidation and NEVER use compound before putting NewGlass on, you don't want any wax on the hull. To apply squirt a small about on a sponge applicator, it's very thin, milky, and wipe on. It will soak right into the hull. I do a section about 4 - 5 ft wide at a time. The are no over lap marks. By the time I get from top to bottom it dry and ready for another coat. They recommend 4 coats. I can do my C30 in less than 4 hours compared to two days of compounding and 2 - 3 coats of wax on / wax off. It's a lot easier on the back too :>)
