polishing & removing rust from stainless rigging?
W
william
while my "new" boat is pretty much parked for the winter, i have a ton of projects to keep busy with. one of them is cleaning-up and repairing rigging. allot of the stainless could use disassembled, cleaned, and polished-up....(ok, so i'm a neatfreak :)). any suggestions on what to use to clean-up/polish stainless. some minor surface rust in places....
John Baumgartner
don't use
steel wool in any form!!!!!!3M Green pads ok but a good coat of wax after
I
IslandJack
I always end up with Brasso
I am a sucker for every new metal polish I see, and I always end up using Brasso in the end. I use a brass wire brush (not steel wire it leaves iron deposits that will soon rust) a tooth brush, Q-tips, and rags. I never bother waxing unless its up high and can't be reached easy. The shine is worth the work...and there are a lot worse ways to spend some time than spending a sunny afternoon polishing up my boat....and listening to some music...and maybe doing some fishing all at the same time. IJ
Bob Fliegel
Stainless Steel Cleaner/Polish
I use a cleaner and polish called "Mr. Douglas Metal Cleaner". I have only found it a boat shows. Its a remarkable product and I use it on all metals (boats, cars, motorcycle, household items, etc). I addition to cleaning and polishing metal I have also found it to be great at removing the oxidation on fiberglass. I don't use and brushes, just some times my finger nail on tough spots and a lot or rubbing. After the metal is cleaned I put a coat of "anhydroxide lanolyn" (the wax obtained from sheep) on everything and its protected for the season. You can get this from any drug store. West Marine also has a produce called Lanocate, imported from Australia, which is also suppose to be very good as a protectant.
Pops Landing
Bar Keepers Friend
and lots of water followed with a good waxing.
W
william
is this any less abrasive than ajax?
isn't this just scouring powder? that does sound like it would do good for tough or rusty spots. ...followed by a polish like has been previously mentioned.
N
nick maggio
FLITZ
I used flitz in a can on my 2001- 290 and it was easy to use and did a great job and the stainless looks like new again ,I did use a scotch guard pad on some tuff spots and this was the first time I did anything to the stainless on the boat for three season's. I will see how well it looks next spring after winter lay up. Nick
A
Al
Flitz for lifelines also...
Flitz works great to get the SS clean and spot free. I also find it works really well to clean the lifelines - makes them look bright white agian!
