Polishing raw stainless steel
RobG
Jun 2, 2004
337
Ericson 28 Noank, Ct
I've just had some 16ga SS plates cut so I can manufacture chainplate reinforcment plates that will bolt to the bulkhead. The raw finish is satin like and I want to polish them. What is the best way to get a mirror like polish?
Dec 25, 2000
6,060
Rob, use red rouge buffing compound...
on a cloth buffing wheel to get the mirror finish you want. Terry
RichH
Feb 14, 2005
4,773
SS Polish
Sand flat with progressively finer paper 180 - 320 - 400 - 600 - 1000 - 1300 grit. A sandpaper 'flap wheel' mounted in a high speed drill is the fastest. Then use a high speed buffing wheel with "tripoli" buffing compound. Tripoli is found in hardware stores in 'stick' form .... right next to the jewelers rouge. The hard part is the laborious sanding and keeping the surface FLAT so that you dont get optical 'waves' in the surface. IMPORTANT: Wear a good mask when buffing with "tripoli" a natural mixture of clay and diatomaceous earth (skeletons of single celled organisms) Red rouges are for polishing red and yellow metals and are too soft for 'white' metals. TRIPOLI
Ed6905
Jun 3, 2004
84
Oday Rhodes-19 Polk City, IA
That's pretty much right
Except use dark grey SS polishing for the first polishing step. If you can find a sisal buffing wheel so much the better. The next step is to color it (bring up the shine) for this you need the white compound with a softer buff. The best would be an airway buff if you can find one. Also 1/3 hp grinder motors really take a long time. My buffing lathes are 7 hp three phase. So if you can find a 3/4 hp baldor or something it will really help.
RobG
Jun 2, 2004
337
Thanks everyone, and Ed, I have a
radial arm saw with a 2HP motor and a 1/2" chuck mounted on the free end of the shaft. I use it with a sanding disk for shaping. I'm going to find and arbor adaptor that fits the chuck and get the buffing wheels you described. Should work well. Thanks again.
Bob B.
16 gauge?
Hello Rob. 16 gauge is only 1/16" thick. How do you plan to use this material? Bob B.
Ed6905
Jun 3, 2004
84
Make sure
the rotation of the buff is such that the buff is rotating toward you.....then buff on the bottom half of the wheel. That way should you catch an edge it will throw the piece away from you.
