Pole Dancing
-na -NA Anywhere USA
Advertisment for selling frog gig poles
Addendum. Kermit advised the actual restaurant chain which by the way was used in a couple Kermit movies
Beneteau 323 Annapolis MD
.... Went to the big box hardware store and bought a 10 foot long closet rod. ....
Some people I know use the painting poles for paint rollers- one piece or twist lock..
Likes: Kermit
WayneH
Tartan 37 287 Pensacola, FL
The boat hooks ride inboard of the handrails with the hook going under the handrail. If you're racing, this doesn't work very well. But for the cruisers, they stay in place well enough. I suppose you got put a lashing on the handle and tie it to the handrail.
Likes: Kermit
Kermit... Hand rails like love handles are over rated.
Likes: Kermit
Aug 13, 2012
533
Catalina 270 Ottawa
How about a ring on the shrouds. You put the end of the hook into it and slide up the shroud. A small loop at the toe rail secures the other end. It might interfere with a jib, especially if it is more than about 110 %
Likes: Meriachee
Aug 1, 2011
3,972
It ain't a real jib unless you can touch the clew while holding the wheel. :)
