Went to the boat today after about 3 weeks of non use. The guy two boats up says, "there's been strange buzzing in your boat." I ask: what kind of buzzing...like bees. "No. " he says, "Like electrical buzzing."
He shows me where the buzzing was coming from -- right behind the electrical panel. I check the panel - nothing wrong that I can see. Only thing turned on was the shore power and the battery charger. I hit the polarity check switch and he says, "That's it! That's the noise."
A little further detective work and he then admitted that he had also unplugged the shore power cord for a few seconds and then the noise stopped.
Then, when I was putting the boat away today, I had a brief (less than a second) buzz from the polarity alarm when I plugged in the shore power cord. Happened just when the shore power cord made contact with the receptacle.
I've always thought the polarity issue was based on a electricity supply problem - am I right?
Or is this likely a bad shore power cord (it's about 20 years old but has given me no problems)? Or is this bad juice from the supply at the box?
Checked both ends of the shore power cord and no signs of any sparking, heat or discoloration.
Can an electrical guru (or a dozen of you) give me a sense of what might be going on?
Thanks so much.
Thanks so much.
