Hello fellow sailers. As I continue down the road of restoration on my 22' Macgregor I'm seeking some advice, first on the cause and then the cure for pitting in the gel coat finish on my boat. Most of the pock marks are on the deck surface which makes me suspect UV damage. There's also a little on the hull above and below the water line...perhaps bubbles in the mix at the time of initial application???? They're generally small, less than 1/8th inch, but they cover a considerable amount of surface area. My thought is to sand down to a smooth finish and then apply new gel coating. Am I on the right track?
