plumbing diagrams
6
Hunter 42 Passage CC New Smyrna Beach, FL
Where can we get a more detailed diagram of the fresh water system on our Hunter passage 42, 1994? Gail
KD3PC
1,069
boatless rainbow Callao, VA
Some other P42 owners may chime in, but I am not sure that you will find any details about your fresh water system. On my 1991, I asked Hunter and there were none.
There is a fresh water tank under the vberth, and one to port under the floor which is under the water heater, which is under the settee. On my boat there was an A-B switch and small trash filter under the floor of the storage cabinet between the nav station and the aft end of the port settee. Some have this valve under the settee or under the water heater.
The main water pump was under the base of the companionway stairs.
For lines it gets worse. Mine were all the gray RV crap, and ran to the starboard of the center line of the boat and was a rats nest in getting to and from fixtures. The check valve for the city water inlet was under the fridge and other than "seeing" it little could be done to replace or service it.
Similar for the shower heads and worse for the stern washdown/shower. Access on these boats is pretty tough, especially for the aft head, as the only access is from the engine compartment and then only if you take a bunch of stuff out.....
Shame on manufacturers for this style of installation (most of the others are similar) for something that needs service or replacement. IMHO.
All the best, and if there is something specific you are looking for, there are a couple of 42CC owners active here that are very helpful.
eianm
Jul 7, 2010
522
Hunter 42 Sydney
om my 1991 H42 my contril taps and screen filters are all under the settee as is the main water pump- all easily accessible. I have a problem with Aluminium oxide in my midships tank( both seem to be the original 20 year old tanks. I am planning to install those 6" screw in inspection cover plates into each tank, thus allowing me to see inside the tanks and hopefully to do some descaling and cleaning as it seems to replace these tanks would be a god awful job!
Oct 24, 2010
6
Our (current) fresh water plumbing issue is a fresh water dripping leak above the aft medicine cabinet above the sink in the aft head. My husband disconnected what he thinks was the gray PVC line from the dock side fresh water connection outside the cockpit step at the Y-valve (A-B valve) immediately aft of the water heater under the port settee. This seems to have slowed the leak but not stopped it completely. As the CC model may be somewhat different in its fresh water plumbing routing, we would be very appreciative if we could communicate with another 42 Passage CC owner. Thanks!
