plastic shelf covers in galley and head
Bill
I would like to replace the sliding plastic doors on the shelves in the galley and head in my C-30. Any suggestions?
John
I asked the same question several years ago and received no responses. I also discovered that removal of some of the sliding doors may prove difficult without breaking. I will follow to see if anyone comes up with a good solution.
W
Windwalker
Smoked Lexan Sliders
I recall having the plastic sliders come out by lifting up. There should be enough of a gap in the upper & lower grooves that you can lift the plexiglass up and be able to clear the lower groove. If you can't get replacements from Catalina direct, then have copies made from a reputable plastics dealer (like TAP plastics). And remember that the height is important, so that you can install the same way. Good luck.
Jeff Martin
Auto Glass dealer....
Bill, I replaced mine a couple of seasons ago...took the originals to an autoglass shop and they cut new plexiglass the same size and thickness... cost me about $15...per set I like the look of the smoked glass over the white arborite...
