plastic mast hoops
3
Starcraft 14 Lake Vermilion
Does anyone know where I can obtain plastic mast hoops for a 1964-65 Starcraft 14-footer? I believe they are about 3" in diameter (at least I know they are bigger than the 1 1/2-inch Sunfish hoops.
NorSea 27 Az., Doing the To-Do list
How about making them by cutting slices from a PVC pipe?
Did that for a small gaf I built and they worked very well.
Greg
Aug 2, 2013
3
Thanks for the suggestions, Steve and Greg
That gives me another potential source for hunting 'em down and a Plan B.
How about a sail maker?
Greg
Mar 22, 2004
733
Hunter 30 Vero Beach
I did a little research on this, and all I could find in the size you need are made out of wood and are $10 each. I also found some threads about making them out of PVC pipe. You would need a 4" PVC pipe cut 5/8" thick.
Aug 2, 2013
3
Really good ideas...
the pvc version and embroidery hoops are both good ideas. i'm going to try both versions next week when i get back to the lake and my boat. of course, for the embroidery hoop the question will be strength given the force of the wind on the sail and durability under wet conditions (marine varnish to protect, I'm thinking). I'll need a link to connect the hoop to the sail but that's no biggie. Thanks, folks!
ChuckMinn
Of course, if you want to make it look old and classy, why not pick up a few wood embroidery hoops in the 3 inch size, about $1.50 each on Amazon at;
http://www.amazon.com/Darice-Wood-Embroidery-Hoop-3/dp/B001B9I2ZY/ref=pd_sim_ac_6
Just an idea.......
Greg
