John Thomas
I purchased my 23 back in June and have had it in a slip on a lake until this past week, when I begrudgingly got it on the trailer, lowered the mast and hauled it home for the winter. Now it is time to make as many of the planned improvments/modifications that I can while the boat is close by. I just wanted to run some of the more major things by some of you before I attempted them.First of all, I have two 12 volt batteries in the cockpit locker that are very hard to access. The locker is so cavernous. It is great that there is so much room but I need to get to the batteries from time to time to fill them, etc. I am considering moving them to the space under the v-berth. It is not currently used for anything else except that the sensor for the knotmeter is there. I would need to build a shelf to make them level and secure. I would also need to run some rather large gauge wire from the batteries to the fuse panel. (Does anyone know much about this type of wiring?) Asside from giving me better access to the batteries this also adds weight to the front of the boat, which I am told I need to keep the boat and trailor from swaying when I tow it. In place of the batteries, I hope to install a 20-30 gallon fresh water tank. this would be located directly below the cockpit floor pretty much down the center-line of the boat. This will allow me to install a recessed shower in the cockpit using a washdown pump. The pumps intake would have a valve that will allow me to draw from the fresh water tank or from a though-hull inlet. The addition of the tank gets rid of the current 5 gallon tank and allows for more room for things that need to be accessed readily. Of course I will install a deck fill and a vent for the tank. I relly do love this boat and I'd like to do some extended coastal cruizing in her if I can. These modifications should make the boat a little more comfortable and user friendly, I hope. Please give me your comments and suggestions.
