placement of depth transducer for Peter and others
Brian Conneely
Peter and the experienced others... I read about some of your findings in the archives regarding the placement of a puck sytle depth transducer on the H23. It was mentioned and I concur that the best place to install the transducer would be in the small compartment underneath the floor board adjacent to the porta john which positions it before the keel. I was curious if 1) you used this location, 2) if so which path (of least resistance) did you run the cable to the guage, and 3) if not than where? I'm building a dash board to mount the instrument guage, among some other newfound necessities, that slide into the companionway when the doors are removed...so the wiring to the electric panel is straight forward. thanks in advance. Brian Conneely h23 Kickin' Back
Jun 4, 2004
2
Hunter 23 Greenport LI
experienced others includes everyone...lol
still looking to see what others did when installing a shoot through hull transducer...in the h23 there is a compartment in the v berth that looks like an ideal spot, has anyone used this?
Apr 19, 1999
1,670
Pearson Wanderer Titusville, Florida
Hi Brian
I placed mine low down next to the bulkhead under the stbd setee in the main cabin, so it's actually just slighly ahead of and beside the keel. This locatio does come out of the water when heeled really hard on stbd tack (lee rail in the water) but I have a solid signal the rest of the time. I'm happy with it. Peter H23 "Raven"
Jun 17, 2004
132
- - pueblo, co
i too am considering the v berth area
looks to me like that puts the puck on centerline and ahead of the keel. yeah or ney? i'll route the wires back to the indicator under the setees. power is nearby and indicator is next to the compass.
