Did mine and here's what I suggest...
Chuck, I'd venture the guess that since your boat is an '83, the motor mounts are in need of replacement. They were on my '77 H 27. Thus, I removed the lag screws holding the mounts into the stringers, blocked the engine with 2x4's (three nailed together, to keep the engine from resting on the oil pan), tacked the motor mounts in place and slid the entire engine forward. The stringers had a small amount of rot, so I drilled and filled with epoxy.Of course, the bolts at the couplers were hopelessy rusted, so I had to use a Dremmel tool to cut them. Its worth the investment of a Dremmel to avoid the aggravation of trying to remove the old bolts. You may end up having to cut the shaft to remove the aft coupler. Since the shaft had dropped into the stern tube and was scored, it was an easy decision to cut it - I had to buy a replacement anyway.With the engine sitting forward on the cabin sole, its a fairly easy job to pull the shaft foreward (although removing the prop was difficult). It also makes for very easy access to the stern tube (which I also had to replace) for installing the seal and bellows.I also installed a flexible coupler, which I also bought from the PYI folks. This necessitated having my brand new shaft cut by more than an inch and having a new key slot milled. With the shaft out, its also a good idea to replace the cutlass bearing. I looked hard but could only find one inch longer than the shaft strut (found it at Fawcetts), so be prepared to cut it with a hacksaw. With the shaft back in place, I slide the engine back (having installed new motor mounts while it was on the cabin sole) and adjusted the engine - shaft alignment. Then I marked where to drill the engine mount holes, slid the engine forward again, drilled, then slid it back. Next, the lag screws were installed holding the mounts, the new bolts placed in the coupler and that was it.... time for a beer (several, actually) Bottom line on what I learned? MUSHROOM FACTOR! I wanted a dripless seal, but ended up replacing a whole lot more. But, it needed it and it works with no vibration and no drips....My boat is across the bay from yours, so if you want to see what I did, email me at tsiklm@ceinetworks.com. Good luck, KM
