pictures
131
Hunter 23 WIll be at a Navy base
Sometimes I fail on the bright category, but I had a post and was asked to post pictures. How do you post pictures on this site, confused? I am sure it is not hard I just can not figure it out.
Also, after all the disasters of the split mast and all since last August, I finally actually had the maiden voyage. What a difference between a Hunter 23 and a San Juan 21.
Jun 2, 2004
5,802
I am interested in those differences, can you elaborate? And will you post pictures of your H23?
To post a picture it first has to be either on your computer's hard drive or you need to have an address if it is located somewhere else, maybe in a Kodak gallery for example. For sure it is easiest if it is on your computer.
If on your computer you can see "Upload Photos or Files" near the bottom. If you click on that it will open a new box. There you select "Browse" and it should put you into your computer's "Desktop". From there you can go and find the picture. Select that picture and it will place it in the box. Notice that you can select more than one. After you have selected one or more then you click on "Upload" and wait until it is done. Nothing to it.
Notice that there also boxes for "URLs". In case your pictures exist outside your computer, somewhere on the Internet, you can insert the address there. In those posts where you see big pictures inline with the text that is a different process. Mainsail uses that a lot, he can explain.
Jun 16, 2010
495
In search of my next boat Palm Harbor, FL
When I upload pictures, I use the "Go Advanced" button at the bottom, then use the "Attachments" button on the next page. A window will pop up, and you can "Choose File" from there. You can also enter in URLs on the pop up.
Pics not in the correct order :S, but you get the idea.
